FWIW...if you
did want to restore service on it, the build would go like this.
- East Walpole Industrial Track is unusable because it's obliterated by newer homes after Chestnut St., Walpole. Must use the route to Foxboro via Fairmount + Franklin + Walpole Jct.
- Follow the Framingham Secondary out of Walpole Station 1.5 mi. to Cedar Jct. This is start of the 1976 abandonment. Southbound junction + old diamond crossing clearly visible.
- If you zoom way in you'll notice there's extant track and a grade crossing from where the power lines cross the ROW just south of the junction to Industrial Rd.
- Electrification FYI: those power lines are the same source that feeds Sharon substation on the NEC, converging at a massive Eversource sub on 1A about 2000 ft. north of Cedar Jct. That's the spot where you'd plug in a Franklin/Foxboro electrification sub for electrifying the current lines.
- Cedar Jct. is named after adjacent Cedar Swamp, and Walpole State Prison a mile or so down the branch is named "MCI-Cedar Junction" after the RR.
- Winter St. by the prison has residential encroachment. FIX: Move ROW back ~450 ft. behind the houses for length of ~3000 ft., re-joining at former Winter St. grade crossing (i.e. industrial access driveway).
- DIFFICULTY: EIS'ing through sliver of wetlands, close shave splitting between 2 homes on Winter. Doable because at fringe of wetlands and only a single-point property encroachment, but is what it is.
- Station: South Norfolk. On MA 115, with nearby TOD on 1A.
- Note the bridge embankments.
- This station used to be called "Cottage"-something, which is why the adjacent car wash on 115 goes by that name.
- 1 residential obstruction south of 115. Weave around, re-join ROW at ex- Winter St. grade crossing.
- DIFFICULTY: Securing easement between 2 homes @ Winter St. Spacing OK, but ROW ownership may have been split between adjacent residential owners.
- Re-route of 1 condo driveway near 1A, moving it south of ROW for grade separation.
- Note extant 1A underpass.
- Station: Wrentham Common @ Depot St. near 1A/140 intersection. Traditional town center of Wrentham, location of (demolished) historic station.
- Used to be called just "Wrentham".
- Power lines on ROW start here, keeping line to south well-buffered.
- Station: Wrentham Outlets/495. Obviously monster TOD & P'nR potential.
- Extant 495 underpass.
- Power line ROW ends at substation by rock quarry @ High St.
- Rock quarry was last freight customer in 1976.
- Possible (minor) obstructions @ Commerce Blvd. Driveway @ SW 'bend' on Commerce needs to be split; ample room, but must square easements. DIFFICULTY: Unclear what redev plan is for demolished factory brownfields in center of block. Probably not big deal because brownfields-under-remediation, many possible paths through.
- Note the siding tracks still extant on the demolished factory parcel, including what looks like a 'pit' track for top-loading at ground level. No idea what business used to be here.
- Station: Plainville, @ W. Bacon St. near 1A. Traditional downtown.
- Extant bridge abutments on West St. south of station.
- Terminal station: North Attleborough. Traditional downtown.
- Junction with Attleboro Branch running east to NEC @ Attleboro Jct./Attleboro Station. Branch obliterated @ US 1, virtually untraceable to east.
- 2 station options: Broadway on the Wrentham Branch ROW, or bending in towards Route 1 on the Attleboro Branch ROW with a couple industrial-crud parcels on Chestnut St. flipped for station redev + TOD.
- Layover yard can go back on the Wrentham Branch north of High St. where there's a tree barrier to protect noise.
- ROW continues intact across MA 120 and I-295 (highway built post-abandonment), but runs into a hard blocker just south of 295 at Chemawa Golf Course, which was expanded on top of it and then infilled over with new homes. Hard to trace the ROW until Depot St. (ex.-Adamsdale Station) right before the RI state line.
- Note the remains of the connecting branch to Franklin forking off to the west at the top tip of the golf course. It's easily traceable on the RI side of the border, but hella obliterated once it re-crosses back into MA.
- Same spot: power line ROW to the east was never a RR structure, and crosses a couple large ponds so unusable for a re-route.
- The more recent 2000's abandonment starts at the ex- RI 123 grade crossing right at the state line.
- I-295 isn't usable for a station site because ROW hits highway at widest possible point between MA Exits 1 & 2.
- Very pronounced density cavity south of N. Attleboro downtown to state line. No compelling audience for even reaching relatively uncongested I-295 when Exit 1 is only 2 miles to the last stop.
SCHEDULE (TBD on any Fairmount skip-stoppage):
SOUTH STATION
Newmarket
Uphams Corner
Four Corners/Geneva
Talbot Ave.
Morton St.
Blue Hill Ave.
Fairmount
Readville
Endicott
Dedham Corporate Ctr.
Islington
Norwood Depot
Norwood Central
Windsor Gardens
Walpole
South Norfolk
Wrentham Commons
Plainville
NORTH ATTLEBOROUGH
So, basically...it's doable from Walpole to N. Attleboro as the only obstructions are single-point and easily mitigated. And at RER service levels it probably would fetch pretty good ridership with the stops either being at prime TOD sites or in traditional downtown centers.
Problem is simply that property-taking of any kind is a royal pain in the ass that chews too much project time, and this is the only buildable commuter rail line in the MBTA district that would have to engage it in-total...with full fragmentation of all but the Eversource ROW rather than having 95%+ of it already in-hand through state ownership and landbanking like other proposals. So unfortunately even if the ridership looks mid-range good and better under RER than conventional peak/off-peak...they are thoroughly disincentivized to take it up for consideration until they've tamed their project backlog on ROW's they do own or which an active RR owns.
I can't really disagree with that. Foxboro, Nashua, Buzzards Bay, Peabody...even a non-broken reboot of South Coast-via-Stoughton...all take precedent. So does Northborough, and so does Franklin-Milford and/or Franklin-Woonsocket. All of them deliver high enough ridership bang-for-buck without requiring an armada of property lawyers, so they wouldn't be doing the district its due diligence slotting this one higher than that glut.
Never say never on Wrentham/N. Attleboro...but it's probably going to have to wait until commute attitudes have changed enough to degunk the legal blockers to creating virgin ROW's. Something other countries with equally strong property rights can do...but we're just not at enough of a desperation point for car-free alternatives to make for a deal-making atmosphere on easement horse-trading. That atmosphere is gonna be well >20-25 years off.
