- Oct 14, 2009
- I havent seen any plans to cover the sides
Here is a pretty extensive render that shows basically everything going up in the seaport from the Sausage parcel/Parcel M over and how the garage is almost invisible unless you know exactly where to look. Even then you can only see very small corners of it peeking out from behind the buildings that will be covering it. Included is Waterside place phase 1A, 1B, the Omni hotel, M parcels, Sausage parcel, you can even see parcel K, which is not included in many renders. This is an older render so building renders like the Omni and the M parcels are obsolete but the general massing is close and we have renders showing what the finished products will actually look like. The sausage parcel has also changed colors and will be black and grey vs yellow shown here. Waterside place phase 1B has the old version here, which I have included the new version below along with The Omni hotel.
-Note: this render does not do justice to what the area will really look like as these are mostly older renders which are not very flattering here. The end result will be much better than what is shown below.
Above is an older render of Omni but that tan building is what it will be. Then on the other side of the garage at the top is Waterside place and the soon to be built Phase 1B next to it. Eventually there is even a plan to put a building up to the left of waterside phase 1B on that circular parcel so it will essentially be blocked in from almost all sides. To even get into this garage from Congress st. you have to go through waterside phase 1B as the garage is behind it and built off the street. Then you have Omni approved and being built soon on Summer st. which will block this from the other side.
Heres Omni from Summer st. The garage is located behind this.
Here is waterside Phase 1B which will cover the garage from the street on Congress st. The garage is also behind this parcel as well. You can actually see a small sliver of the garage to the left of the tower.
The hole that says "Seaport Transportation Center" is how you get to the garage from Congress st. which is again located behind this tower and you can see a small piece of the garage here as well.
This means that pretty soon the garage will not be seen from views like this below, because the Omni will be built in front of it covering it from view. Then you can already see Waterside place phase 1A blocking it from the other side and phase 1B is going to be started very shortly on the left of Waterside place in the picture below completely blocking it from Congress st. Then the M parcels, Sausage parcel, Waterside place phase 1B and the parcel next to it will cover it from most angles on the other side unless you are on WTC ave.
I am not sure of the parcel name to the left of Waterside place Phase 1B, but this is a recent render below showing that something will be built there as well covering this garage even more than shown in the first render I posted of the entire area. So below we see the garage, the Omni, Waterside place phase 1a and 1b, the parcel next to it, the M parcels, and the Sausage parcel, all going up on different sides of this garage essentially boxing it in and mostly removing it from view. Unless you are on WTC ave those other roads to the left of the garage are pike on/off ramps and so you will only get a quick view of the garage never sitting idle.
