Re: Mass Art Dormitory
@JohnCostello
In fact you are correct, the existing gigantic MWRA sewer main that joins into others on this site is the reason for the building being located in the back of the property. The pipe runs from the pump house (behind the Artists Residence dorm on Ward Street) and curves through this site to join with others under Huntington Avenue.
Moreover, the curved base of the tower aligns with the required setback from the curved pipe underground. The height of the curved base is determined by the dimension needed to raise the pipe if it ever needed to be replaced. Above the minimum height for maintenance, the tower becomes a more efficiently shaped rectangular slab, appropriate for its dormitory use.
