^^ Right. The question I have is what keeps them from running underground shuttle service where they can. (Alewife–Kendall, Park–Andrew, North Station–Tufts Medical Center, North Station–Kenmore, Bowdoin–Aquarium/Maverick, depending on if they want to risk going under the harbor)
The rationale for doing this is that it's better to have some movement in the system rather than none, better to have a less-than-ideal method of transport for the cities of Boston and Cambridge than to have none.
I can think of a few issues:
1) cost: self-explanatory; the T probably wouldn't make much revenue at all from this, especially with the busses out
2) doesn't discourage folks from going out (folks who don't need to be going out), which has all sorts of problematic ripple effects
3) turning trains: there's a crossover at Kendall, so Alewife–Kendall would be fine, but everything else is a little tricky. From what I can see, turning at Kenmore would involve reversing on to the loop, and then reversing again off at the other side. There are no X's at Tufts Medical Center, so trains would either have to surface to cross at BBY, or turn at Chinatown instead. (Which would mean that the OL shuttle would parallel the GL for its entire length.) No crosses at Andrew, so it's either terminate at Broadway, or run single tracked to Andrew. (Which could also be done with Tufts, but I digress.) There are no crosses between Gov't Center and Maverick, so unless the T wants to risk running the shuttles under the Harbor (see below), a BL shuttle is pretty much pointless. (I can't see a Bowdoin-GC bouncer making sense.) One thing they could conceivably do is run GL shuttles from Symphony to North Station, since there are X's both at Symphony and Pru.
4) external power supply: from what I know, power for subway trains is generated off-site and is transferred to the subway. What if those connections are damaged? Do we end up with stranded trains, compounding the difficulties already faced by the City? (And if a BL train got stranded under the harbor... oy.)
It seems to me that the intention of The Powers That Be with this shutdown is to encourage employers to give employees the day off. I'm not sure this is the most effective way to do that, but it may be the only tool available to them at this time.
