JumboBuc
- Jun 26, 2013
Replying here to Blackbird's post in another thread:
You can play around with projected flooding depths here. It takes until about a 100-year storm in the 2070s before Logan sees significant storm surge inundation, and in that case much of the city is already under water. Plus Logan can shrug off a storm surge after the waters recede much better than, say, the entire South End can.
Obviously its all a system and everything is interrelated, but by the time we end up with water deep enough to flood Logan, Logan will be pretty low on our list of concerns.
Logan is in much better position for sea-level rise than many would assume. Sure, it's right on the water, but most of it actually isn't very low-lying. The neighborhoods of East Boston around it, for example, are at much more flood risk than the airport itself is.I'm wondering how Logan is planning to handle rising sea levels should the prophecy come to pass. Even if (by some miracle) sea level rise isn't pronounced enough to flood Logan, would Boston need a second airport anyway if it keeps growing? If so, where would that second airport go, or are Manch and PVD enough?
IMG_2689
IMG_2690
IMG_2695
IMG_2704
IMG_2700
IMG_2702
IMG_2709
IMG_2708
