The Roche Bros is trying to get approval for some outdoor seating on Summer St. Hearing is on April 16th.
http://www.universalhub.com/2015/downtown-crossing-roche-bros-seeks-ok-outdoor-cafe
I can just imagine what the price on groceries will be like there when the supermarket opens. Through the roof!![]()
I'd guess that the prepared foods (which should be primarily located on the ground floor Summer St. entrance) will be price gouged, but no more so than things already are at whole foods. Everything else, at least from what I've seen in the Wellesley store, should be relatively normal, if a bit on the expensive end.
Also, not that this is particularly relevant, but I thought I'd note that Millennium has said that similar to the Ritz and the Loews, there will be no internal access to the Burnham building from Millennium tower. Residents will have to walk around via Washington St.
Today I counted 19 floors up to the protective grill. I can no longer see into that, so I don't know if they've got 2 or 3 floors built behind the grill. But they're somewhere in the low 20s, past the one-third mark on number of floors and zooming towards the halfway mark. As the base floors have much higher ceilings than residential floors, they're even closer to halfway on total height.
True, but the residences above the 32nd floor have higher ceiling heights than the residences below and that needs to be factored in. According to the Millenium Tower website, the ceiling heights in "City Residences" (up to 32nd floor) are 9 feet, versus ceiling heights of 10 feet in "Grand Residences" (from 33rd to 55th floors). I'm not sure, but I suspect that the ceiling heights in the "Penthouse Units" (from 56th to 60th floors) are even higher.
DZH, you're way off. They're on 26 going to 27. Maybe you need to get your eyes checked
