- Jan 22, 2012
^ I always like to imagine that the state purposefully built the new Suffolk County Jail with conversion to hotel in mind.
They are accessed at the building entrance at 66 Hudson Street, near the intersection at Harvard Street.
The affordable units are all below 60% AMI, with 31 units at or below 30% AMI. Maloney Properties, Inc. is conducting a Department of Neighborhood Development (DND) affordable rental lottery located at One Greenway. The application period for this lottery has ended. Occupancy selection by lottery on May 15, 2015. Occupancy beginning July 2015.
http://www.66hudsonatonegreenway.com/
This is getting a set of stairs stepping down from Surface Rd along the south side of the mid-rise and land onto Harvard St as well as another mid-rise south of that, right?
Correct, there is a small terraced park from the Surface Road/South Station Connector to approximately Harvard Street, with stairs connecting the two levels. And Phase 2 is mid-rise/pseudo row houses extending on down Husdon Street to Tai Tung Street.
ugh...all that ramp does is institutionalize the whole monstrosity even more.
Worst outcome of 2015.
Yes, plus a row of townhouses.There is a lowrise but as far as I know it was always planned to be a seperate phase and to be seperated form the other building by that garden/terrace space.
No railings for wheel chairs....that first bend at the top looks like a doozy.
4.8.5 Handrails
If a ramp run has a rise greater than 6 inches or a horizontal
projection greater than 72 inches, then it shall have handrails
on both sides. Handrails are not required on curb ramps.
Handrails shall have the following features.
- Handrails shall be provided along both sides of ramp
segments. The inside handrail on switchbacks or dogleg
ramps shall always be continuous.- If handrails are not continuous, they shall extend at least 12
inches beyond the top and bottom of the ramp segment
and shall be parallel with the floor or ground surface.- The clear space between the handrail and the wall shall
be 1 1/2 inches. Handrails may be located in a recess if
the recess is a maximum of 3 inches deep and extends
at least 18 inches above the top of the rail.- Gripping surfaces shall be continuous, without interruption
by newel posts, other construction elements, or
obstructions.- The diameter of width of the gripping surface of a
handrail shall be 1 1/4 inches to 1 1/2 inches or the
shape shall provide an equivalent gripping surface.- The top of the handrail gripping surfaces shall be mounted
between 34 inches and 38 inches above ramp surfaces.- A handrail and any wall or other surface adjacent to it
shall be free of any sharp or abrasive elements. Edges
shall have a minimum radius of 1/8 inch.
Is there not a low-rise still to be built to the south of this?
