Re: 1350 Boylston
Too true!
It already is that world though, isn't it? Isn't the entire city covered in overly restrictive zoning laws that force VIRTUALLY ALL development proposals to ask for special permissions?
There is nothing special about this proposal, the Fenway, or these particular zoning regs.
^This.
They are trying to get a variance. Which they have every right to do. And with the development in the decade since the Fenway master plan
(WHICH HAS DONE VERY WELL TO GUIDE THE NEIGHBORHOOD UP TO THIS POINT) makes perfect sense to seek.
Fenway, you keep getting upset that the developer "overpaid" and is now trying to recoup costs by building a larger building then the 2004 zoning deemed necessary. ISN'T THIS A GOOD THING? Doesn't that show that the zoning worked well, and has managed to positively increase property values to the point that the only way to build is to build taller then envisioned?
I want to reiterate this point as well: If not granted a variance to build taller, they will have to cut corners in other ways. That will be by value engineering the building, particularly the facade (the part that you, the neighborhood resident, will have to see EVERY DAY) to death. THAT is how you wind up with a Kensington; not by granting developers variances. IIRC, That's what happened with the Dainty Dot too. We were going to get a beautiful building with the factory as a base. Then the complaints started, and now we have something that may or may not be
okay, but certainly not as good as the original proposal.
Regarding the "high spine": I don't see how this effects it at all. As I already said in
this post here, The Point will still be the taller building, by a good five floors. Also, there are several parcels immediately south of this parcel that can be redeveloped in a manner to still allow the gradual step down to the 4-6 story heights in the neighborhood proper. This particular building, on this particular parcel, has no effect on the high spine concept.
It seems that the core of your argument is that you feel disrespected because an entity that makes it money building buildings is trying to make money building buildings. As Matt is hinting at above, I have not heard a single argument of substance against the building. Only that it "violates blah blah blah ten years ago blah blah high spine". Matt asked some really great leading questions above, I look forward to your responses.
