Schorschico
New member
- Mar 14, 2014
The "Access to the Bus" and "Egress from the Bus" tables for each route tell you how many transfer to/from other bus routes. Using Route 36 as an example, on PDF page 131, shows 81 people transferring from Route 36 to Route 39 and 20 people transferring from Route 36 to Route 16
Thank you for the tip, I didn't know where to get the data!
The results are very much as expected. Basically, an OLX to RV will be great for lines 30,34,34E,35,36,37,40,40 and 51 with shorter routes and faster connections with the OL (the main use of all of them). Of the possible loss of bus-bus connections, only 39 sees some transfers (makes sense) and in a much smaller range 16.
So I would propose to make them all shorter and increase the length of 39, 16 and 42 until RV to minimize the impact on bus-bus transfer and keep bus service on Washington street.
32 will remain "as is" waiting for an OLX2, and the other routes affected, 21 & 31 could remain the same as OL "feeders".
