Twenty20 @ Northpoint | 20 Child Street | Cambridge
It looked so promisingly blue and magnificent in those renders
Looks like Northpoint will be Seaport: Part Two.
Couldn't get a good picture from the train, but the first bits of windows and facade are starting to go up on this thing.
I have a question about the siding being placed on Twenty/20 versus the Pier 4 Residences. They are going up at the same time and look very similar. However as depicted above Twenty/20 has aluminum (?) brackets placed then the insulation over that. I assume that next will come the panels. The residences at Pier 4 seems to have just the panels go up all at once without the steps that are done at Twenty/20. Is this a new way of construction? I am not an architect or engineer.
Twenty/20 is building up the exterior walls in place: Aluminum studs, covered by Densglass sheets, waterproofing membrane, and then (presumably) the cladding. Pier 4 uses precast concrete, which is built up offsite and hung on the building.
The precast is good if you're doing brick, concrete or pseudo-stone for your surface material. The on-site buildup is better suited to Alucobond or similar materials.
Thanks for your answer. It will be interesting to compare the two buildings once they are done.
The folks at 20/Twenty are doing it the right way for a long term, durable solution. They are building a serious back-up wall that will do all the waterproofing, insulating, air tightness. Then they will hang some sort of cladding in front of that. This is a 50-100 year construction method often seen in institutional buildings. Pier 4 style wall is much less expensive, but the waterproofing is being done by a slab of concrete (which is porous) with spray insulation on the backside (which puts the insulation on that wrong side of the so-called waterproofing) and the jointing is waterproofed with a simple silicone sealant joint. If the owner was feeling generous they might have two sealant joints.
If you were going to ask me to invest half a million dollars or more to live in a place built new. I would take the 20/Twenty construction as a much much better investment.
cca
