JeffDowntown
- May 28, 2007
Re: 111 Federal St. | Formerly Trans National Place (Winthrop Square) Part 2
And runways, also, are pragmatically aligned based on predominant wind directions. They are not randomly placed. They are aligned to minimize the frequency of high cross-wind takeoffs and landings -- a huge safety issue in aviation.
So you need aviation corridors aligned with the prominent wind directions. Logan already skates on the edge of aviation best practices in safety with the sharp turnouts over the water on takeoffs. We are asking for an engine out on takeoff crash that is caused by the aircraft being in a steep bank at the time of engine loss, causing a low altitude, non-recoverable stall.
^ Depending on which way your runways are aligned. In our case 9/27 is all thats screwing us over. The FAA height guidelines arent law, and can be given exceptions. Menino knew that. This tower will be basically directly behind 1IP when looking from Logan. If your flying under 200 ft directly over the roof of 1 international place your already screwed.
