A Chicagoan
- Nov 28, 2020
Through the rearview mirror:
by Bos Beeline, on Flickr
IMG_0973 by Bos Beeline, on Flickr
IMG_0976 by Bos Beeline, on Flickr
IMG_0984 by Bos Beeline, on Flickr
Wow, between these twisting/sloping columns and the huge cantilevers, this is one complex building.
Seeing this daily, this whole project is the definition of complex. They must have run into 10000 hurdles from onset. Foundation work took nearly THREE YEARS. I went back and looked it up, this was supposed to open in 2020 then pushed to EARLY 2021 so I can't imagine things went anywhere near according to plan, pandemic aside. They must be 1.5-2 years behind given said complexity with this thing taking a month per floor on top of the interior work that is sure to take a good while.
That sounds right, I guess that's why nearly every other building down here is a box!While no inside information on the matter, there were noted several times big work stoppages on site for unknown reasons in 2019. My guess is engineering ran into some challenge and needed to go back to the drawing board several times.
Looks like an extraordinary amount of rebar in this building, I guess that huge cantilever requires it.
After what happened in Miami, I would hope all contractors are looking again at their construction techniques. I'm sure the rebar/concrete ratios have to be precise to preserve both over time.Looks like an extraordinary amount of rebar in this building, I guess that huge cantilever requires it.
I am a little surprised ocean front construction doesn't require epoxy-coated rebar, to resist the salt corrosion issue. It is used in most northern highway construction at this point, IIRC.After what happened in Miami, I would hope all contractors are looking again at their construction techniques. I'm sure the rebar/concrete ratios have to be precise to preserve both over time.
