This photo may help.
The northern side of the tower extends to the row of steel columns going up the left side of the elephant ramp.
https://flic.kr/p/raoaVC
But those lifts go right down to the lobby. Doesn't even look like much of a core - are those thicker walls running between the units of the building thicker transverse walls?
Could it be that it's just steel beams and transverse walls all the way up?
I thought it was legislated (or at least strongly suggested) that buildings over a certain height were required to have such a core after 9/11- is that not actually the case?
Either way, I'm so accustomed to buildings at this height having a concrete core nowadays that I'm completely unused to not seeing one.
IBC 2012 said:1022.2 Construction.
Enclosures for interior exit stairways and ramps shall be constructed as fire barriers in accordance with Section 707 or horizontal assemblies constructed in accordance with Section 711, or both. Interior exit stairway and ramp enclosures shall have a fire-resistance rating of not less than 2 hours where connecting four stories or more and not less than 1 hour where connecting less than four stories. The number of stories connected by the interior exit stairways or ramps shall include any basements, but not any mezzanines. Interior exit stairways and ramps shall have a fire-resistance rating not less than the floor assembly penetrated, but need not exceed 2 hours.
Exception: Interior exit stairways and ramps in Group I-3 occupancies in accordance with the provisions of Section 408.3.8.
http://publicecodes.cyberregs.com/icod/ibc/2012/icod_ibc_2012_10_par253.htm
The building codes & NFPA say that shafts must have a 2-hr rating, not necessarily be constructed of concrete. Concrete is naturally fire-resistant and effortlessly provides the necessary rating. You can achieve fire ratings with steel & gyp assemblies like so, but it doesn't provide the same structural stability benefits as concrete: http://nationalgypsum.com/products/..\File\istudcavity.pdf
