Officejab
- Nov 30, 2011
I see the problem! How about small grooves that look big to small-diameter wheels (skateboards + inlines) but small to large diameter wheels (wheelchairs and bikes)?One question - How do you make an anit-skateboard barrier which is ADA-compliant?
I can't be the only person to wonder how many skateboard pedestrian accidents will occur on the footbridge -- particularly at the ends
I don't want to be anti-skateboard. It gives me no pleasure at all. But what does it look like when skateboarders travel along a large arching bridge?Why do you want to be anti-skateboard? All you need is clips on any edges or railings to keep them from grinding. If they're just traveling along, leave them be....
The mix of tools, and skills, and gravity seems likely to put skateboarders on a trajectory (for lack of a better word) that while perhaps safe in itcelf, will not fit well with the trajectories of cyclists and pedestrians.
The only inherent bias in my statement above is the belief that cyclists and pedestrians and wheelchairs are the "design use" of the bridge, a bias which I believe the numbers and design simulations support. Having built a bridge biased against skateboarders, it seems unsafe to mix it in close proximity with a skatepark biased entirely in their favor, because it is mixing incompatable trajectories that creates unsafe conditions.
^ i have to agree. If the skate boarders are just using the board as a mode of transportation then there is absolutely no problem.
...or people on Segways.Found$ -- there is no problem if the skateboarders are carrying the boards. However, if they are riding then there is just as much a problem as if multiple bicyclists are riding in a "peloton"
I will admit a crazy bias in favor of Segways (although I'm a non-owner), but they are another mode, like skateboards, that is an elegant "like-walking-but-better" way to get around that sadly is hard to mix safely with actual walking.
Good design reduces hurt. Bad design makes it more likely.The only way to keep people from getting hurt is to keep them from doing anything.
Is everyone else on this board a cranky old man? If you are worried about a "heffty teenager on a skateboard" on this bridge being a danger, what about a person in a motorized wheel chair? those are heavier and can go by far faster. What about a person on a bike distracted by the view off the bridge? a falling bike is alot more dangerous that a board with wheels. What about a person texting? I have seen countless videos of people texting while walking and falling into fountains, getting hit by cars, etc. etc. Yes skateboarders can be a danger if they are not paying attention, but so can every other mode of personal transportation. The only way to keep people from getting hurt is to keep them from doing anything.
So basically your answer to his question is yes.
